Battery Conditioner/Tender Recommendation - NCRS Discussion Boards
  • Don E.
    • April 30, 2005
    • 65
    I am looking for guidance regarding recommendations on battery Tenders or Minders that continuously monitor/charge batteries during storage. I see advertisements in the Driveline, Hemmings, Corvette Central, etc. for a variety of products that range in price from $19 - $149
    I have a red top Optima in my '58 and my desire is to keep it as long as possible.
    Any suggestions/recommendations would be greatly appreciated.
    Don
  • Steven S.
    • August 29, 2007
    • 571
    Re: Battery Conditioner/Tender Recommendation
    I have a Deltran Battery Tender and really like it.
      • 11643
      I have 3 Battery MINDers, and like them very much. No issues at all, and they work well.
      • Clem Z.
        • January 1, 2006
        • 9427
        i have a $19 one from walmart that is made in the USA by schumacher electronics the outfit that runs that top fuel dragster sponsored by the US ARMY
        • Tom H.
          • December 1, 1993
          • 3440
          Battery Minder Plus !
          Tom Hendricks
          Proud Member NCRS #23758
          NCM Founding Member # 1143
          • Richard T.
            • June 23, 2008
            • 67
            I use the 0.75 Amp battery tenders on my lead acid water filled battery cars. Battery Tender make's them for 6 or 12 volt battery's. No water loss and these tenders use very little electricity. I always keep the negative cable disconnected or use a battery cut off switch on my cars. The Optima battery hold's a charge much longer than a water filled battery. Your call If you want one for your 58; the tender can be used on the resin filled Optima. Leaving the tender hooked up to your Optima will do no harm and will show a green light when the battery is charged. The Battery Tender from Deltran Corporation 801 International Speedway Blvd. DeLand Flordia 32724. Ph 386-736-7900. Email: service@batterytender.com
            • Stuart F.
              • August 31, 1996
              • 4676
              I use a Battery Minder from Restoration Battery on my repro 63 Restoration Battery. I have had water loss during the hot summer months here in Florida, so I have to check the water level more routinely if the car sets for a couple weeks or so. I regularly disconnect the gound as well.
              I also have a Black and Decker unit on my spare Optima Battery sitting on a wood block on the floor beside my car. It keeps a full charge and is ready to go should my Restoration (show) Battery fail.
              Stu Fox
