55 directional lsignal - NCRS Discussion Boards
  • Don S.
    • February 1, 2000
    • 476
    How does the steering wheel cancel the turn signal apparatus
  • Roy B.
    • February 1, 1975
    • 7044
    Re: 55 directional lsignal
    It's the part screwed on the reverse side of the steering wheel , check this guy out it may help
    • Steven B.
      • June 30, 1982
      • 4016
      http://www.1953chevrolet.com/1953_Ch...orn%20Problems
      Hey, that's Al Sleet, the Hippy Dippy Chevy Man!
      • Don S.
        • February 1, 2000
        • 476
        The articles do not address how the cancelling device works . I may be missing a piece. It is the piece that catches the cancelling device protrusion (maybe) I cannot see anything that triggers the cancelling device ---any help or pictures.?? The directional signals worked before I got the car painted. and did not after.--It was put together wrong or a piece is missing.
        • Roy B.
          • February 1, 1975
          • 7044
          The plate on the back side of the steering wheel pushs on that arm the spring is pulling that moves the signal arm up or down , you sure the switch on the hand brake and flasher are OK or adjusted correct.
          • Don S.
            • February 1, 2000
            • 476
            Thanks for responding guys and thanks for the terrific picture Roy. but-- I still do not understand. there must be something on the back of the steering wheel that engages the cancelling mechanism. I still think I am missing a part. can anyone explain?? thanks
              Don -
              That same cancelling assembly is used on '56-'62 Corvettes, and it's cancelled by two pins pressed into the forward face of the steering wheel hub; with the wheels straight ahead, the pins are at 8 and 10 o'clock as viewed from the driver's seat.
              • Roy B.
                • February 1, 1975
                • 7044
                This is the part screwed on the back of the steering wheel (see the tab) that's what cancels the turn signal 53 to 55
                • Don S.
                  • February 1, 2000
                  • 476
                  Thanks guys. the picture that Roy posted show what I am missing. I guess my painter probably did not know where it went so he left it off. I will have to see if he still has it.
