Recently bought an original 1965 set for my driver. When cleaning the spinners, the following points came to mind.
First: Do we all agree the detail / intricacy / workmanship of the center emblems is fantastic ? Evidently, they've not been exposed to much sunshine over 44 years
. Some silver deterioration evident on the pole of the checkered flag. There are several reproductions out there; do any come close to matching the originals ?
Second: If you're going to reproduce the emblem, why not get it right
? Some have the upper square (and opposite lower corner) on the checkered flag as white, some as black. One outfit offers you a choice. I know the '65 TIM&JG says black, and I'm almost sure the '66 is the same.
Third: Remember the hilarious thread on indexing the cross flags so that the valve stem hole would appear directly below the cross ? Well there is a sort-of indexing of the emblem. See thumbnail of the spinner backside. Notice the 3 black marks I made at the location of the pins that mount the plastic emblem. They are not at equal 120 degree angles. The pin at the top is at a greater angle to the two lower ones. Very evident when you try to install the plastic in the spinner casting. Anyone know why ??
. Some silver deterioration evident on the pole of the checkered flag. There are several reproductions out there; do any come close to matching the originals ?Second: If you're going to reproduce the emblem, why not get it right
? Some have the upper square (and opposite lower corner) on the checkered flag as white, some as black. One outfit offers you a choice. I know the '65 TIM&JG says black, and I'm almost sure the '66 is the same.Third: Remember the hilarious thread on indexing the cross flags so that the valve stem hole would appear directly below the cross ? Well there is a sort-of indexing of the emblem. See thumbnail of the spinner backside. Notice the 3 black marks I made at the location of the pins that mount the plastic emblem. They are not at equal 120 degree angles. The pin at the top is at a greater angle to the two lower ones. Very evident when you try to install the plastic in the spinner casting. Anyone know why ??
