66 Steering column color - NCRS Discussion Boards
  • David M.
    • April 30, 2003
    • 32
    I am trying to find out what color the column should be. I have been told by different people different things. One said it should be painted semi-gloss, one said satin, another said it should be powder coated. Is it paint or powder coat and if paint satin or semi-gloss?
  • Wayne M.
    • March 1, 1980
    • 6414
    Re: 66 Steering column color
    There were only 2 glosses of black used on 1966 Corvette interiors. Low gloss (3 deg) [Ditzler 9292 or Dupont 4466 L], and this was to go on Directional Signal Housing, Mast Jacket, Steering Wheel Hub, and Steering column Escutcheon, etc. The what-goes-where is from the '65 Ditzler chart, but am sure it's the same for 1966, as the manufacturers' codes are the same. Hi gloss (60 deg) went elsewhere (there's another short list, if anyone's interested).
    I thought that the steering tube itself (that goes through the firewall) was a higher gloss than that (but that was a service unit I bought 15 years ago, and production may have differed).
      David -
      It's paint, more satin than typical semi-gloss; SEM #39143 Trim Black (aerosol can) works very well for this.
      • David M.
        • April 30, 2003
        • 32
        I am interested in the rest of the list you mentioned.
        • James W.
          • December 1, 1990
          • 2671
          David,
          I know you are asking for information regarding a 1966 model, but I have included some pictures of a 1965 steering column in an unrestored car with 29,xxx miles on it. You can see the varying gloss between the steering wheel hub, steering column mast jacket and the escutcheon plate near the dash.
          Hope this helps.
          James West
          • Wayne M.
            • March 1, 1980
            • 6414
            David -- here's the rest of the story; again, locations from the Ditzler (PPG ?) 1965 chart, but the black codes are the same for 1966 MY as well. Let me finish off the the parts that have BLACK low gloss (3 deg) from yesterday's post; (cont'd)... Glove Box Frame, Linkage Cover Panel Inner (what the heck is that ?)
            -- Then, for black interior cars: Headliner, Rear Compartment Inner Area. Linkage Panel Cover Outer (?)
            -- Next; Full Gloss (60 deg): Used on Winshield side and upper Garnish Mouldigs. Upper Garnish Mouldings, Halo Panel, Hardtop Garnish Mouldings, Door Upper -- Inner, Kick Panel Retainer, Lock Pillar Return Flange (what's this ?) and Cap (Inner).
            Here's the 1966 interior refinish charts from Chev Service News. Corvette is only 2 columns (no flat [zero gloss] anywhere).
