Front Brake Lines - NCRS Discussion Boards
Front Brake Lines
  • Alger R.
    • September 30, 1999
    • 279
    Front Brake Lines
    Do any C3's call for the armor (spiral spring) on the front cross-over brake line and left side front brake line? I know the two lines from the Mstr Cyl going to the Prop Valve have the armor but I thought those were the only two. I purchased a complete set of brake lines / gas lines / vapor lines from "In-Line Tubing" for my 75 and didn't realize that the two front lines had the spiral armor on them. Before I return them, I wanted to check with the experts.
    AL
    75 Convertible
    L48 M20
    Bright Green / Saddle
    • 6960
    Re: Front Brake Lines
    Alger,
    I Replaced My 72 Coupe Brake Lines On The Front And They Had The Armor Only From The Comb. Valve To The Right Front, The Left Front Was Just A Small Line W.fittings.
    • Alger R.
      • 279
      Re: Front Brake Line armor
      Thanks for your response. I was thinking that maybe the early C3' or late C3's had the armor on the lines? Any further info by anyone out there would be appreciated
      AL
      75 Convertible
      L48 M20
      • Harmon C.
        • August 31, 1994
        • 3228
        I think that crossover line in front has the armor on a 75.
        Lyle
          • 3422
          Hi Alger,
          On my 71 the 2 lines from the master cylinder to the distribution block, the short line to the driver's side, and the long cross-over line to the passenger's side, all have armor.
