My '65 was having an on-again-off-again ignition problem (driving down the road fine and then off, just like you pulled the coil wire, then back on again). Now the car won't start at all. The coil is showing 2.5 ohms, and I believe this is too high, but not sure if it is the real problem. Haven't checked the points yet. I was reading a motorcycle magazine and saw a guy that had a very similar problem with his Honda. Turned out to be a main fuse was cracked. Does my '65 have a "main fuse" ? If so, where ? If not, any other thoughts ?
Mark
Mark
