Rear Spindle Bearing Seals - NCRS Discussion Boards
  • Gregory H.
    • January 9, 2009
    • 3
    I am restoring an original 64 Rear Trailing Arm.
    The bearing seals that you buy today, are they like the original seals?
    See attached picture. Seal has 3 parts, metal ring with 4 tabs, rubber seal, and back metal plate.
  • Gary R.
    • April 1, 1989
    • 1798
    Re: Rear Spindle Bearing Seals
    No I haven't seen those new in years. The CR seals will work fine though and no one will know otherwise.
      • 43219
      Greg-----
      The seal you have pictured is a GM #3794002 (if it's the inner seal as it appears to be) or a GM #3794006 (if it's an outer seal). The GM #3794002 was discontinued in 2001. The 3794006 was discontinued in 1984. These are OLD technology seals. The current seals are as follows:
      inner--- CR 16757
      outer----CR 19803
      If you buy the GM seals what you get is the CR or National seal in a GM box.
      • Gary R.
        • April 1, 1989
        • 1798
        Also to add to what Joe said, the NAPA seals are also CR although they cost more, almost double then the same CR's I get from my industrial supplier. SKF is now the parent company of CR so you will find them in different packaging.
        How's it going Joe?
          • 43219
          How's it going Joe?
          Gary------
          How's it going? Well, the temperature here was about 60 degrees today with clear blue skies, my health is fine, I've got no debts, at all, and I've got a few bucks in my pocket. So, how could things really be any better?
