Adjusting Big Block Lifters - NCRS Discussion Boards
  • Mark A.
    • February 1, 1996
    • 299
    When I reassembled my 69 390 hp engine, I adjusted my lifters by turning the pushrod with my fingers until it would not move, then went about 1/8 turn more. The engine ran fine. I looked in the shop manual, and it says to go 1 turn past 0 preload. I reset the lifters to this spec, and the motor would not run due to the valves being held open. I reset them back to where I initially had it, and the engine runs great. Why does the shop manual state to adjust the lifters this way? Thanks for the help. Mark
  • Wayne W.
    • April 30, 1982
    • 3605
    Re: Adjusting Big Block Lifters
    That is exactly the way stock lifters are adjusted. One turn down. You have to give them time to bleed down though.
    • Don W.
      • September 30, 1997
      • 492
      Here's a good reference article....Don
        • 15706
        I prefer to jiggle the pushrod up and down until you can't feel any play, then go 1/2 to 3/4 turn. If the pushrods are well lubricated, you usually can't feel an increase in turning torque until the lifter already has some preload.
        The other issue is crankshaft indexing. AFAIK all Chevrolet hydraulic lifter cams are on the base circle when the piston is at TDC of the compression/firing stroke.
