A buddy is looking at purchasing a complete '70 3.36 Positration axle and putting all the parts in his '63 carrier, including the companion flange, which has a different spline count than the '63 drive flange.
The 65-70 crush sleeve is also different. I think it's the same length but a different ID to be compatible with the geometry of the later drive pinion.
Another issue is whether the '70 axle came from a manual or automatic. The auto uses a different companion flange designed for a larger u-joint. I don't know what trans the doner had.
Has anyone done this? Can a 65-70 ring and pinion be installed in a 63 carrier using a '70 manual trans companion flange and crush sleeve?
