65-67 Side Pipe U-Nuts Original vs. Replacments - NCRS Discussion Boards
  • Rich P.
    • January 12, 2009
    • 1361
    I don't know if this has been noted in the JM but I thought I'd post pictures of original side pipe mounting u-nuts compared to replacements.
    I have included 3 pictures of u-nuts. The original clip can be spotted from the later replacements in 3 easiy point.
    First from the front the originals have a M stamping while the replacments don't.
    Second and most easily spotted the originals use a captured square nut while the replacements use a hex nut. This can be easily seen when the 2 clips are installed on the fender skirt splash shield.
    Third the original u-nuts have a wider opening allowing them to be installed onto fiberglass as well as the steel splash shields.
    As a side note the overall width of the original is shorter than the replacements allowing them to be more easily installed onto the rockers.
    Rich
  • Craig O.
    • July 31, 1983
    • 207
    Re: 65-67 Side Pipe U-Nuts Original vs. Replacements
    I also will add that the plating on my originals resemble black phosphate
    • Wayne M.
      • March 1, 1980
      • 6414
      Re: 65-67 Side Pipe U-Nuts Original vs. Replacments
      This agrees with the nuts I examined on a friend's original car -- see link
      https://www.forums.ncrs.org/showthre...64562&uid=6034
      P.S. Admin: strange that this link (Oct 24 2008) would not have been among the "similar threads" selected at the bottom. No idea what the search criteria are .
      • Larry M.
        • January 1, 1992
        • 2688
        Rich:
        Excellent info.....thanks for posting.
        Larry
        • Rich P.
          • January 12, 2009
          • 1361
          Craig,
          you are correct all originals I have removed have been black or grey phosphate.
          Wayne,
          thanks for the links. I saw some questions in your link as to thread and types of screws so here is what I have seen. All side pipe u-nuts were 10-24 thread. The screws securring the covers to the rockers were a large pan head phillips while the 2 screws attaching the front hanger brackets to the fender skirt splash shield had a 5/16" recessed and flanged hex head. I should have some originals laying aroud and will post some pics of them later.
          Larry,
          your welcome. What fun is it knowing something but not sharing it?
          Rich
          • Rich P.
            • January 12, 2009
            • 1361
            OK,
            I dug some original front hanger bolts out. And while I was doing that I wanted to see if it was the same pt# as the 68-72 wiper door limit switch bolt and yes it is. If you look on the 65 AIM under UPC N-14 sheet 3 the screw is is listed as pt# 9421033, then if you check the 69 AIM under UPC 1 sheet D1 you will see the limit switch L bracket to wiper door hinge arm screw is pt # 9421033 also.
            I have included 2 pictures to show the bolts (sorry I have a hard time calling anything with a hex head a screw).
            I have seen many different headmarkings on these. The ones here have what I refer to as the T/F headmarking.
            Rich
