RPO 684/687 Differences :The Details - NCRS Discussion Boards
  • Justin B.
    • March 1, 1996
    • 478
    I know that the RPO 687 had the large "cups" on the bottom of the small brake shoe hold down springs but were they on the RPO 684 cars? I havn't heard of them being present on the early big brakers but what are your opinions? Thanks guys!!
  • James G.
    • May 31, 1976
    • 1556
    Re: RPO 684/687 Differences :The Details
    Not exactly sure what you want here Justin, but I received the following from Fran Estereicher, Corvette collector that loves RPO brake/ suspension stuff and has access to GM Engineering from the 50's and 60's.
    I attached the spring picture. does that help?
    • Justin B.
      • March 1, 1996
      • 478
      Aren't the springs RPO 686, not 684 or 687?
      • Bill M.
        • April 1, 1977
        • 1386
        The 684 and 687 pull-back springs are dark green.
        • Joseph T.
          • April 30, 1976
          • 2074
          Here they NOS.
          Same size and dimension as standard pull back springs but these are high heat treated...and painted dark green.
          Joe
          • James G.
            • May 31, 1976
            • 1556
            Originally posted by Joseph Trybulec (930)
            Here they NOS.
            Joe
            So Joe, What are the springs Franz sent me above ?
            • Justin B.
              • March 1, 1996
              • 478
              That is an RPO 686 set-up, not RPO 684 or 687
              • Joseph T.
                • April 30, 1976
                • 2074
                Jim
                I don't know by the picture..I would have to check the part # in an old parts book. Just a guess but it appears to be a genuine spring kit. Not sure of the application.
                Joe
                • James G.
                  • May 31, 1976
                  • 1556
                  Thanks Guys,
                  I learned something here. Back in the day no one looked, we just changed the parts. Doug Hooper and I were talking last week about this. After each day of racing it was not uncommon to completely do a 'new brake job' at the race track.
                  NEW shoes, NEW Springs, and NEW drums. We even rebuilt wheel cylinders. A major RPO set up came in a wooden box for $202.00. And as I remember, there were springs and a quick steer adapter in there also.
                  • Franz E.
                    • March 1, 1997
                    • 96
                    Re: RPO 684/687 Differences : SPRINGS
                    SPRINGS very boring subject, unless you were a spring designer in a previous life.
                    • John N.
                      • February 1, 1975
                      • 451
                      Franz, good to see you in Florida. Would you give a lesson on measuring brake spring tension. I do have fish scales. Also why was the small spring used for the race RPOs and the large springs used for the street metallic RPO.
                      Regards
                      • Joseph T.
                        • April 30, 1976
                        • 2074
                        Franz
                        I wonder what kind of brake springs were used on my 59 Buick LeSabre which has its original finned drums.
                        Joe
                        • Franz E.
                          • March 1, 1997
                          • 96
                          Hi John:
                          • Franz E.
                            • March 1, 1997
                            • 96
                            Hi Joe:
                            • Joseph T.
                              • April 30, 1976
                              • 2074
                              Hi Joe:
                              Franz..If memory serves me correct the fronts are cast iron and the rears are aluminum..or vice versa.
                              Next time I get a chance I will look. The car has less than 50,000 miles but I did have a brake job...so who knows if they replaced the springs.
                              Hope you are well..
                              Joe
