#911 water pump help - NCRS Discussion Boards
  • Roy B.
    • February 1, 1975
    • 7044
    Any one know where I can buy a water pump kit to include the shaft ,bearing and seal so that I can rebuild my spare #911 using my original impeller,(seen here) rebuilt's change to the new steel impeller which causes the temp. To run higher. Thanks
    • 43247
    Re: #911 water pump help
    Roy-----
    It looks like you already have the seal (unless you're lacking the seat that goes with it). In any event, I would think that you could buy the shaft/bearing assembly from Bill Mock or Arthur Gould. Also, I believe that Corvette Central sells rebuild kits for waterpumps.
    Another source, especially if you happen to be going to the Los Angeles area: Salgado Automotive on Whittier Bl. in south LA.
    • Roy B.
      • February 1, 1975
      • 7044
      Thank you vary much because I dont buy anything from dealers I dint know that.
      Bill Mock or Arthur Gould you have a number for them?
        • 43247
        Roy-----
        Bill Mock----(918) 333-0748 mockauto@aol.com
        Arthur Gould----(631) 269-0093---www.arthurgouldrebuilders.com
