TI Amp 1115005 - NCRS Discussion Boards
TI Amp 1115005
  • Mark F.
    • January 1, 2003
    • 139
    TI Amp 1115005
    I see that K & B Special Projects is advertising in the Driveline a 1115005 TI Amp. They state it is stamped correctly. Has anyone purchased one to see if the stampings are correct? Are they different from the originals as most of the NOS ones are?
    Mark
  • Wayne M.
    • March 1, 1980
    • 6414
    Re: TI Amp 1115005
    Originally posted by Mark Franken (39215)
    I see that K & B Special Projects is advertising in the Driveline a 1115005 TI Amp. They state it is stamped correctly. Has anyone purchased one to see if the stampings are correct? Are they different from the originals as most of the NOS ones are. Mark
    Another thing to consider, depending on which C2 year (or 1968) you may be considering this repro for, is the design of the back cover.
    I'm not sure, after reading the Service News and the TSB, just when the re-designed rear seal (and the wider [flat] lip on the cover) came into production -- maybe others can provide.
    First design cover on left.
