65 wiring placement ? - NCRS Discussion Boards
  • Donald S.
    • January 23, 2008
    • 183
    i need some help with the mounting locations for the plastic wiring holders that go through the inner fenders on the left side and right side i cant find a page in the aim that gives measurements from reference points . i am wondering if these were measured points , or did they just install 2 per side with no real definitive placement? thanks Don..
  • Mike M.
    Director Region V
    • August 31, 1994
    • 1463
    Re: 65 wiring placement ?
    The holes had specific and consistent locations, however, As the panels were pre-drilled before being supplied to the assembly line, the specs you are looking for would not be in the aim.
    Perhaps someone can jump in with information beyond the AIM and/or reference measurements from original cars.
    HaND
    • Dale S.
      • November 12, 2007
      • 1224
      Donald, check you email. dale
      • Donald S.
        • January 23, 2008
        • 183
        thanks Dale >
        thanks Dale does your car have the k66 option ? and if so does the wiring run down the passenger side with the surge tank hose ? thanks Don anyone with a 65 bb that can help it would be appreciated >
