63/64 Idler Pulley stud - NCRS Discussion Boards
  • Dan H.
    • July 31, 1977
    • 1370
    Hi All, I believe I have a 'repro' idler pulley stud. It makes the idler pulley protrude forward creating a misalinement of the fan belt. All other pulleys align nicely except this one. Does anyone have handy the length of the 5/8 hex area on the stud? Looks like mine needs a 'trim' job!
    Dan
    1964 Red FI Coupe, DUNTOV '09
  • Michael H.
    • January 29, 2008
    • 7477
    Re: 63/64 Idler Pulley stud
    Dan
    Dan,
    I have a used original Idler stud. The hex section measures 1.450", or slightly less than 1 1/2".
    The stud should be installed without a lock washer between it and the water pump.
    • Dan H.
      • July 31, 1977
      • 1370
      Thanks Michael, the stud measures out OK, sooo, the problem might be with the repro idler pully assembly setting to far forward. Don't have an original to compare offhand, would be interesting to see what one measures when laying flat on it's mounting tabs to center of the pulley to compare to what's on my 64. No lock washer under the stud but maybe the water pump hole boss may be different. (thicker etc.).
      Dan
      • John D.
        • December 1, 1979
        • 5507
        Dan, I was wondering how you were able to drive your 64FI car to most every regional and national on the west coast covering 13,000 miles with a pulley issue.I do believe you have driven your 64 FI car to more shows than 99% of NCRS members.
        And on top of all that driving your have been in the high 90's point wise!!!! Good job my friend. JD
        I prefer a putting the LWC in a nice cozy trailer though.
        • Dan H.
          • July 31, 1977
          • 1370
          Thanks John and Michael, stud was as it should be, removed idler assembly, supported the back of the shaft on a vise, used a socket and a 'Harley' hammer to set the pulley back 1/8", perfecto! Just wasn't pressed on far enough on the shaft.
          Dan
          • Dick W.
            • 10483
            Dan, supports the old addage, just use a larger hammer
            Dick Whittington
            • Irby G.
              • November 1, 2001
              • 267
              Hi Dan, just measured mine from my '63 340.It's 3.25" to the center of the pulley.
              Aloha,
              Irby
              • Stuart F.
                • August 31, 1996
                • 4676
                If you have everything you need, Dan, I'll bow out except to say I have all the original pieces off my 63 340 hp too, in case you or anyone else needs a second opinion.
                Stu Fox
                • Dan H.
                  • July 31, 1977
                  • 1370
                  Thanks Irby and Stu, 3.25" is a good reference point and for anyone else who has alignment issues with the idler pulley. In my case the pulley was not pressed far enough onto the shaft for proper alignment.
                  Dan
