Restoring my car - wheel question - NCRS Discussion Boards
  • Chris E.
    • November 3, 2006
    • 1335
    Ok guys, I have a question about wheels. I have a very early 67 (#100183). I'm restoring the wheels at this point. Here's what I've got.
    One wheel with no stamp.
    Three "B" wheels
    One "DG" wheel.
    The TIM/JG says they should either be DG or DC wheels. Yet the expert midyear guy I'm working with says that really early 67s had "B" wheels. He has enough B wheels for me to complete my set of 5.
    I'm nervous about that option because the TIM/JG doesn't say ANYTHING about B wheels. So I'm assuming I'd lose my points there in the hands of a more junior judge. (assuming that the B wheel for early car comment is correct)
    What should I do?
    Chris Enstrom
    2011 Z06, red/red
  • Timothy B.
    • April 30, 1983
    • 5200
    Re: Restoring my car - wheel question
    Chris,
    I think it's safe to say B wheels for your car and I think no problems for judging.
    The DG is probably dated 2-67 and is a spare someone added but is a correct later 67 rally, look close at the unstamped wheel for B stamp at the hole for valve stem. If they are unmounted can you post some pictures of the DG and unstamped wheel showing dates inside the rim, this will tell the whole story.
    • Chris E.
      • November 3, 2006
      • 1335
      Thanks Timothy, I'll have to go shoot some pictures of the wheels.
      Not all of them have stamps on the tread part of the wheel that is covered up when the tire is installed. I'll have to look again more closely.
      But, it sounds like "B" wheels all the way around is the way to go.
      Chris Enstrom
      2011 Z06, red/red
      • Peter L.
        • May 31, 1983
        • 1930
        Chris - For a car of that low a VIN, I'd expect the wheels to have an 8 66 (Aug 1966) manufacture's production code so check inside the rim for the info; but I know all of the B wheels I have seen are 8 66.
        Also, I figure by now most 67 judges know about the B wheels and if not, it will be your chance to educate them and don't forget you can always move the call up the ladder.
        It will be interesting when you get the manufacture's production code info from the wheels and post them for the wheel code stamps and also for the one without the wheel code stamp.
        Pete
        • Chris E.
          • November 3, 2006
          • 1335
          Ok, so here's the summary.
          B wheels (3 of them) all have the 66 8 code. Interestingly enough, two of the three have the "66 8" code stamped on one of the surfaces that is more vertical, and the third wheel has it stamped very close to the KH main stamp on the main surface of the wheel.
          DG wheel (1 of them) has 15x6 JK 67
          Blank wheel (1 of them) has nothing except the Kelsey Hayes stamp and something else next to it that looks like a design
          One of the "B" wheels
          My only "DG" wheel
          [img]
          My only blank wheel
          Chris Enstrom
          2011 Z06, red/red
          • Timothy B.
            • April 30, 1983
            • 5200
            Chris,
            Great pictures, the DG wheel looks like a 1-67 date but the 1 is hard to make out. That would be the first 1-67 DG wheel I have ever seen, usually 2-67 is common date. Here is a pic of the DG I had.
            The unstamped wheel is interesting, I would not get rid of it and I would keep looking for the date. Is this wheel welded like the others and is the offset the same and 6" wide just to double check.
            • Chris E.
              • November 3, 2006
              • 1335
              Originally posted by Timothy Barbieri (6542)
              Chris,
              I'm assuming it does, since they were all on the car (except for one of the B wheels I believe) and the car drove straight and had no issues. I didn't measure the offset or the width. I can do that when I get home.
              Chris Enstrom
              2011 Z06, red/red
              • Ara G.
                • January 31, 2008
                • 1108
                Very interesting, as the spare in my 67 Coupe is blank as well.
                • Chris E.
                  • November 3, 2006
                  • 1335
                  What VIN are you? Early car? Late car?
                  Chris Enstrom
                  2011 Z06, red/red
                  • Ara G.
                    • January 31, 2008
                    • 1108
                    December car. Have looked and looked and NO stamp. All others on my car are large DC. I was scratching my head for a while on that one. Obviously a prior owner may have swapped it, lost it, destroyed it, etc. But judging by how the prior owner of 19 years took care of the car, and how he saved EVERYTHING of the car's, it seems doubtful
                    • Peter L.
                      • May 31, 1983
                      • 1930
                      Chris - I agree with Tim that it looks like a 1 near the 67.
                      On the blank wheel can you take a picture of the center (front) of the wheel. There were some variations of the GM and KH stamping during the production runs perhaps someone will be able to make a comparison to the wheels they have and provide some date info. Pete
                      • Peter L.
                        • May 31, 1983
                        • 1930
                        Ara - On the blank wheel can you take a picture of the center spider (front) of the wheel. There were some variations of the GM and KH stamping during the production runs perhaps someone will be able to make a comparison to the wheels they have and provide some date info. Thanks, Pete
                        • Ara G.
                          • January 31, 2008
                          • 1108
                          Hi Peter, I will take a picture one night this week, but last time I tried to upload a picture to the board it didn't upload. Can't remember if it was because it was too big or what. If I have trouble, I can email it to anyone, and see if they can upload it properly.
                          • Chris E.
                            • November 3, 2006
                            • 1335
                            Ara, for uploading pictures, go to photobucket or something and then just link to it.
                            Peter, I'll shoot more pictures and post them.
                            Chris Enstrom
                            2011 Z06, red/red
                            • Timothy B.
                              • April 30, 1983
                              • 5200
                              I have seen some B wheels where the valve stem hole is drilled through part of the B stamp. It's possible the wheel is B wheel but interesting to hear of one with no stamp. Now we have no stamp, B stamp, DC stamp and DG stamp.
                              Chris, If there is a date inside that wheel I think it will be by the 15x6 JK if you can find that. Your picture does not show that stamping.
