The dipstick tube is incorrect and I need to replace it with a correct tube. I understand the tube is a press fit into the engine block. Since I do not plan to keep the old tube I thought I might remove the old one with a l vicegrip on the tube hitting the vicegrip with a small hammer (assuming I can find room to do this). For installing the new one I am open to suggestions but I could drill a hole (or slot) just slightly bigger than the tube in a metal plate, slip the plate over the tube down to the flange at the end and use a hammer on the metal plate to install (again assuming there is room to do this).
I am looking for comments or feedback on how others have done this task on an installed engine (car would be up on blocks). Also any tips/comments on tube circumferential alignment during installation as I assume once it is seated it cannot be turned if it is off position.
