pad thickness,J65 brake shoes - NCRS Discussion Boards
  • John A.
    • February 1, 1982
    • 48
    Does anyone know the original thickness of the sintered cerametallic material pads on the shoes? Carbotech has indicated they can install segmented pads but want to know what thickness material to use.
    Thanks, John
    • 15706
    Re: pad thickness,J65 brake shoes
    Should be in the AMA specs...
    • Stuart F.
      • August 31, 1996
      • 4676
      Does Carbotech claim to have EPA approval of their material? That's is what killed previous plans/attempts to reproduce Sintered Metallic shoes/material last I knew. Is reason I replaced mine with Matrix Ceramic shoes.
      Stu Fox
      • Jim L.
        • September 30, 1979
        • 1816
        On the surface, this seems like a problem in simple arithmetic: Determine the radius of curvature of the shoe cores and subtract that from the radius of curvature of the resurfaced drums. The difference ought to be pretty much the desired segment thickness. What am I missing here?
        Jim
        • John A.
          • February 1, 1982
          • 48
          I plan to use a different material as well. Mike ( Carbotech) has a couple of materials that will perform as well as the old cerametallic material, but its less heat sensitive.
          • Wayne M.
            • March 1, 1980
            • 6414
            Thanks, John
            If we're really talking about J65, (and not J56), this thickness question was discussed a while ago (link) https://www.forums.ncrs.org/showthre...94191&uid=7712
            The thread started off on the subject of Z06 then wandered around into J65.
            Here's a shot of NOS front 3794191 J65's.
            • Jim W.
              • April 1, 2006
              • 228
              Nice to know I still have a good bit left on these 43K orig.
