Smoking - NCRS Discussion Boards
Smoking
  • Harry L.
    • December 22, 2008
    • 370
    Smoking
    1in10 times when I take my 66 big block for a ride especially in the hot summer months, I"ll bring my car back and if I let it idle for 15 minutes or so ,it will smoke only out of the right exhaust. The smoke color is white and maybe a little blue. Like I said, not every time. what could be the causes?
  • Bill I.
    • January 29, 2008
    • 554
    Re: Smoking
    Harry, you're not going to like this, but sounds like a coolent leak into one of the cylinders. Hope not. Bill.
    • Harry L.
      • December 22, 2008
      • 370
      Re: Smoking
      Thanks for responding! my coolant is still full to the top as it has been for years. Do you still think that could be the reason ?
      • Timothy B.
        • April 30, 1983
        • 5202
        Re: Smoking
        Harry,
        My vote is for valve guide seals and wear in valve guides. If it's not using any abnormal amount of oil I would leave it alone.
        • Michael W.
          • April 1, 1997
          • 4290
          Re: Smoking
          Originally posted by Timothy Barbieri (6542)
          Harry,
          Agreed. Could be that your car only likes being driven 9 times out of ten
          • Joe R.
            • July 31, 1976
            • 4552
            Re: Smoking
            Harry,
            Check to see if you heat riser is opening all the way or at all. Sometimes it is rusted shut and on an extended cruise the RH exhaust will warm up and give off a little gas. Yes, your car will run with the heat riser completely shut. At least for a while until the valves become angry.
            JR
            • Harry L.
              • December 22, 2008
              • 370
              Re: Smoking 66 vette
              Valve seals fixed my smoking problem. Lucky! DUTCH
