"63 Rear window stainless trim - NCRS Discussion Boards
  • Douglas G.
    • April 30, 2001
    • 58
    How difficult is it to remove this trim for polishing? Are special tools required? Should one use a glass repair shop?
  • Doug F.
    • November 1, 1983
    • 322
    Re: "63 Rear window stainless trim
    it is high among the top 10 of unpleasant jobs on a 63, real easy to scratch the paint or worse yet bend the chrome trim, all it takes is a window hook tool and nerves of steel, also if you happen to break a retainer clip you have to pull the window out to change it, also once you're all done removing and polishing you still have to reinstall, more drama, if you hire a glass shop make sure they know what they are doing, if its not bent up think about buying a hand held pollishing kit and do it on the car, good luck,
    • Douglas G.
      • April 30, 2001
      • 58
      Thanks Doug, sounds like great advice. I have started polishing in place and I think I should continue since I still have the main wiring harness to install.
