Attn:Joe Lucia;1970 LT1 Delco Coil Confusion - NCRS Discussion Boards
  • Larry E.
    • 1691
    Hello:
    Restoring a 1970 Z28 with LT1 which would also applies to Corvettes. Being
    an owner of both Corvettes and Camaro's are paths cross often. I belong
    to both Corvette and Camaro forums. Joe: look at the below thread that
    was on the Camaro forum the other day. Let me know if it is true or not.
    Here Is A Little Coil History For Your Question
    Coils Are Embossed With The Three Digit Code That Represents A Coil Assembly - Most 12 Volt Coils Are Phyiscally The Same Except For The Embossed Three Digit CODE - Early Coils Do Have Delco-remey In A Smaller Font
    The Three Didgit Code Is In Reference To The Coil Bracket With A Certain Degree Angle Needed For An Engine And Air Cleaner Application
    THE 293 COIL ASSEMBLY IS THE STANDARD COIL BRACKET USED ON MOST CARS AND TRUCKS AND USES A 25 DEGREE ANLGE
    SPECIAL HI-PERFORMANCE CARS USE COIL BRACKETS WITH MORE THAN THE STANDARD 25 DEGREE ANGLE AND WILL VARY ON APPLICATION
    Original Delco-remy Coils From 1955 To 1967 Use The 12V
    083 12V
    204 12v
    267 12v
    Original Delco-remy Coils from 1966-67 use BR
    270 BR
    Original Delco-remy Coils Changed In 1968 To B-r
    270 B-r 293 B-r
    270 Br Coil Was First Used On The 1966 Chevelle With The 4 Bc And The Big 17" Air Cleaner
    1968-72 Corvette - 1969 Z28 W/ Cowl Induction Used The 270 B-r
    1969 Z28 W/O COWL INDUCTION 298 B-R
    1970-72 Z28 Used The 270 B-r
    Hope This Answers Your Questions
    Joe: Is this true about the coil bracket angle? If anybody else as any
    ideas on this (Like Terry M.) please chime in.
    Thanks; Larry
    Larry
    LT1 in a 1LE -- One of 134
    • 15613
    Re: Attn:Joe Lucia;1970 LT1 Delco Coil Confusion
    I can verify part of this.
    For PRODUCTION coils the number is the last three digits of the ASSEMBLY part number. That ASSEMBLY included the coil and bracket, because that is the way the assembly was shipped to the Corvette assembly plant. It is probably reasonable to assume that similar practices applied to other body style assembly plants.
    The differences in the coil mounting brackets may have included the angle of the bracket as well as the spacing on the mounting holes, and whether one side was slotted or both sides had holes for the mounting hardware.
    I am skeptical of the B-r. I have seen coils with B R, and B-R, but never a lower case "r." Not to say they never used the lower case -- I've just never seen it. It is possible my experience is more parochial than that of others. FWIW: I have been told the BR is for Ballast Resistor.
    • Dan L.
      • November 10, 2008
      • 81
      The coil bracket angle was different on the '70 Z because of the rather large dual snorkle air cleaner.
      DAN
        • 43246
        Terry and Larry-----
        I agree.
        • Brad M.
          • July 31, 2005
          • 262
          This post does not even mention the 272 coil which was used on the 70 and 71 Corvette Lt-1
