I am wondering when you change the bushings in the a-arms, struts, rear suspension parts do you need a special tool to push the bushings in place or will a little lube and pressure work. Also is there a right and wrong way to put the centre shaft back in the A-arms.
Just looking for some input so I don't do it wrong. I tried to search the archieves but did not find much. I may have not been looking in the right place.
Thanks Rob
Thanks Rob
