What is the wattage of the high beam lamps on the 68 4 headlight system?
Is there any negative effect on the electrical system by subsituting the 2 high beam lamps with lamps that are rated at 100 watts each without any modifications to the wiring or use of relays?
In other words, if I take out the high beam lamps and plug in 100 watt lamps am I doing any damage?
Thank you,
Kurt
Thank you,
Kurt
