Battery Gauge R & R - NCRS Discussion Boards
Battery Gauge R & R
  • Bill C.
    • December 1, 1991
    • 177
    Battery Gauge R & R
    Getting ready to replace the battery gauge on my 67. I hope to accomplish this the sneaky way, just sliding the cluster out enough to remove this gauge. I'm asking if since there are 2 wires on this gauge, is there a polarity on the gauge. Thanks for all responses, Bill #20328
    Re: Battery Gauge R & R
    Yes, there is - just leave the wires in the plastic connector body so you don't change it.
    • Joe R.
      • July 31, 1976
      • 4552
      Bill & John,
      You don't even have to loosen the cluster. There is plenty of room to change it without all the fuss! Unless of course your hands are akin to hams!
      JR
      • William C.
        • May 31, 1975
        • 6037
        Don't really need to move the cluster to get the panel and the two gauges out, pull the seat to give some room (I've done it with the seat in also) remove the screw holding the twin gauge packages in place, disconnect electrics and you have it. BTW disconnect the battery before trying this, and if you need to test the meter, a 1.5 volt battery momentarily connected to the terminals should give a full scale deflection. Don't admire the devlection, just touch the 1.5 volts to the meter, see it move and disconnect immediately.
        Bill Clupper #618
        • Bill C.
          • December 1, 1991
          • 177
          Bill:
          "Remove the screw holding the twin gauge package" . You lost me, I thought there were 2 nuts threaded onto the rear of the gauge and that would allow removal. What twin gauge package ?
          Bill #20328
          • Joe R.
            • July 31, 1976
            • 4552
            Bill,
            You will have to reach up inside and remove three screws that hold the backing plate for the two small gauges. After first removing the wiring.
            You can't put it back on wrong. They are keyed to the gauges. Slide the backing plate with the two gauges out and onto your work bench. Replace your amp gauge and reverse the process.
            Piece of cake!
            JR
