Steps to replace fan clutch - NCRS Discussion Boards
  • Don W.
    • September 30, 1997
    • 492
    What are the step to remove and replace the fan clutch? I think all I need to do is use a large screw driver to prevent spinning and then remove 4 or 5 bolts. There is no need to remove the fan shroud, belts or other items. 69 427/390HP no A/C. Am I correct?
    Don
  • Jack C.
    • September 30, 1992
    • 1090
    Re: Steps to replace fan clutch
    It will come off attached to the fan because it is bolted to the fan when the fan is removed. Depending on the year you're working on, the water pump will have studs into it or the bolts holding the fan and clutch will screw into the water pump hub which is behind the pulley. You don't have to touch the shroud.
    Jack Corso
    1972 Elkhart Green LT-1 Coupe 43,200 miles
    Top Flight 1994, 2018 & 2021
    • Harry S.
      • July 31, 2002
      • 5293
      Don, what exactly do you mean by replate the fan clutch?
      • Don W.
        • 492
        Harold,
        My fan clutch is bad and I need to replace it. The current unit on the car is older after market unit. I'm getting a new GM replacement unit since I can't find a correct dated unit which would likely be too old to function properly anyway. I need to remove the old unit from the front of the fan housing and re-install the new unit.
        Don
        • Harry S.
          • July 31, 2002
          • 5293
          I should clean my glasses more often, I read replace as replate.
          • Jack C.
            • 1090
            Also, make sure you wrap a heavey cloth towel around one blade to hold it still to loosen the nuts/bolts.
            Jack Corso
            • Michael W.
              • April 1, 1997
              • 4290
              I doubt you will need to use or want to use a screwdriver, too much chance of it slipping and causing damage.Especially if it's the liquid kind with ice and OJ.
              The torque on the retaining nuts or bolts is quite low.
