guage cluster removal - NCRS Discussion Boards
+ More Options
Posts
  • Ray G.
    • June 30, 1986
    • 136
    I am going to rewire the 67 ragtop and will need to remove the guage cluster to send out to be refurbished. Any publications showing how this is done? I have some shop manuals but they are for 68-82.
  • Bob R.
    • June 30, 2002
    • 1595
    Re: guage cluster removal
    If you search the archives I think yoiu will find several posts giving hints and suggestions for the removal of the cluster. It is not difficult but soes take some time.
    One suggestion that is worth doing is to remove the drivers seat to allow some room for you to work. Another is to use short legnths of thread all to hold the cluster in place while allowing you some room to disconnect and reconnect the wires.
    • David D.
      • January 1, 2005
      • 416
      Just to help save you time.....Here's a link to a great 'Cluster Removal' article written by John Hinckley.
      Part 1
      http://www.lbfun.com/warehouse/tech_...ster%20pt1.pdf
      Part 2
      http://www.lbfun.com/warehouse/tech_...ster%20pt2.pdf
      Hope this helps....it did for me.
      David
      • Tim E.
        • April 1, 1993
        • 360
        In addition to the John's articles that David references, I have a copy of this picture handy so I can label connectors as I remove them:
        • Philip A.
          • February 26, 2008
          • 329
          Dave
          Do you have a better copy of Part 1? This is exactly what I need but can barely read it. THANKS!
          Phil
          • Kirk M.
            • June 30, 2006
            • 1036
            Buy the 5 1/4"-20 X 6" bolts suggested in John's article. You cut the heads off then mount them in the cluster screw holes. This allows you to slowly remove the cluster while unplugging and labeling things. Once the cluster is completely unhook, you just pull the cluster off the ends of the bolts and you're done. First break down the rag joint and unscrew the steering column so your cluster will easily come out. Don't forget the oil pressure line actually has oil in it - be ready. All of this is in the article, and it is well worth following.
            Kirk
            • Harry S.
              • July 31, 2002
              • 5330
              I didn't cut the head off, but you get the idea!
              • David D.
                • January 1, 2005
                • 416
                Originally posted by Philip Arena (48654)
                Dave
                Phil
                Phil,
                Sorry, but actually I don't. I had to increase the dpi's when I printed it to read. Play around with your printer and you'll hopefully get a copy good enough to read. Or maybe if John reads he can re-post the original for better clarity.
                David
                • Ray G.
                  • June 30, 1986
                  • 136
                  Thanks a million gents! My new Lectric Limited harness will be here Monday, and I will start the project.
                    Dave
                    Phil
                    Phil -
                    You have mail.
                    • James R.
                      • September 30, 2005
                      • 93
                      I pulled my cluster out in the fall and followed the article by John and everything went smooth. I also used the picture of the back of the cluster that Tim Ehlers mentioned to label each connection. Made the change out of the bulbs and reconnecting everything easier. The clarity of the first article I agee is not too good. Hopefully you can get a readable copy of the first article since Corvette Enthusiast no longer has back copies of those. Good luck.
                      Jim
                      PS - I believe John had another suggestion to stack phone books on the floor board to make the floor level while you are working on your back below the dash. I wish I thought of that when I did mine.
                      • David D.
                        • January 1, 2005
                        • 416
                        Now that's a nice hint.....I'm going to be re-installing mine soon and never thought of that. What a great suggestion. Thanks
                        David
                        • Ray G.
                          • June 30, 1986
                          • 136
                          When I did the cluster and rewiring in my 65 several years ago, I removed the drivers seat, placed nice cushions to rest my back on and used small florecsent bulbs so I could see without burning myself. I hope this one goes as well!
