New Cam for '68 HT block - NCRS Discussion Boards
  • Ron F.
    • December 1, 1980
    • 20
    Hi,
    Since I don't have the original engine in my 64 I am taking some liberties with it's restoration and going on a nostalgia trip with a 327 HT block and heads from a 1968 Vette. I am looking for advice as to camshafts. I want a mild lope and solid lifters, just for the cool sounds. I am going to run three deuces, a 4 speed, Hooker headers and side pipes. I'm not looking for mega horsepower and my racing will be confined to street drags with my brother-in-law. I just want to have fun.
    Ron
  • Jim T.
    • March 1, 1993
    • 5351
    Re: New Cam for '68 HT block
    If the 68 HT engine is intact, just use the 68 HT's cam, it is hydraulic and will give a nice sound. The 68 HT from the factory was a 11:1 compression ratio. IMO it is necessary to run the compression the original type engine came with to get the lope. A mechanical cam with a low compression engine is just going to give you some tappet noise and no real performance.
    • Ron F.
      • December 1, 1980
      • 20
      Hi,
      I should have mentioned that the cam is not original and I am unable to ID the manufacturer or type. The lifters are missing so I don't know if they were solid or hydraulic. I definitely want solids so I am taking no chances and swapping out the cam.
      Ron
        • 43271
        Originally posted by Ron Frey (1303)
        Hi,
        Ron
        Ron-----
        For what you're after, I'd use a clone of the GM #3972178 (cast 3972182) cam as used for 1970-72 LT-1's. You can get a Crane-manufactured cam and lifter kit from GM under GM #12364054.
        • William V.
          • December 1, 1988
          • 399
          Ron
          I built a 388 cu/in stroker (60 over) flat top pistons and 10.5:1 compression and installed a COMP solid lifter cam #12-000-5 (intake lift = 505 & duration= 284) (exhaust lift 499 duration 291). valve adjustment is .012 intake & exhaust. The power band is 2500 to 6900 rpm. The engine sounds and runs awesome and kicks up to 6500 in a flash. It also idles at 700 rpm with manifold vacuum at 14 to 15 lbs and is very streetable.
          Good luck
          BV
          • Ron F.
            • December 1, 1980
            • 20
            Thanks Joe, Bill and Jim,
            I'm leaning toward the LT1 cam right now.
            Ron
              • 15706
              You can also buy the LT-1 cam from NAPA under the Sealed Power (Federal Mogul) brand, CS-1145R and the lifters are AT-992.
              Search the archives for "327 LT-1" under my screen name for information on the details of this configuration and lab and chassis dyno tests - 80 percent torque bandwidth was 2100 to 6750 with useable power to 7200 and close to 300 SAE corrected RWHP at 6500.
              Everything except the connecting rods (and LT-1 cam) is OE '65 L-76 and L-79 (one of each were the starting points). The secret to the broad torque bandwidth is the cam and the secret to the high top end power is the head work.
              • Ron F.
                • December 1, 1980
                • 20
                Thank you Duke,
                I ordered cam and lifters this morning.
                Ron
                  • 43271
                  Duke-----
                  Yes, the equivalent cam and lifters can be purchased through NAPA under the part numbers you described. However, they'll cost about 225 bucks at NAPA. The Crane-manufactured GM #12364054 kit carries a GM list of $226. It should be pretty easy to buy it for 25% off list, so one should be able to save about 50 bucks going with the GM kit.
                  • Ron F.
                    • December 1, 1980
                    • 20
                    Hi,
                    I Googled the part # and found Northern Auto Parts. Cam - $76, lifters - $2.60 each. Manufactured by Federal-Mogul.
                    Ron
