Correct 69 Engine Fan Clutch - NCRS Discussion Boards
  • Don W.
    • September 30, 1997
    • 492
    Does anyone know where I can get a correct engine fan clutch for my 427/390HP. I spoke to Pacific Corvettes and their web site shows a GM clutch and aftermarket clutch. After speaking with Pac Vettes, I was told the GM clutch is a GM replacement model but will not meet judging standards.
    Thanks for you input.
    Don
  • Don W.
    • 492
    Re: Correct 69 Engine Fan Clutch
    Also, what is the points deduct for using the current GM replacement fan clutch? Don
    • Erik S.
      • January 1, 2005
      • 407
      If I remember correctly there are 6 points allocated for originality to both fan AND fan clutch - so assume both 50-50 then 3 points for the clutch. Potentially configuration issue and date - so take 40% off the 3 points - maybe 1 point deduction I would say (but I have only chapter judging experience).
      Erik
      • Jack C.
        • September 30, 1992
        • 1090
        Item number: 140292753291 ebay
        Jack Corso
        1972 Elkhart Green LT-1 Coupe 43,200 miles
        Top Flight 1994, 2018 & 2021
        • Erik S.
          • January 1, 2005
          • 407
          incorrect date for 69
          • Jeffrey A.
            • October 22, 2006
            • 273
            But correct for 68 427/390?
            • Don W.
              • 492
              Any rough idea what the point difference is between the $150 after market fan clutch and the $250 GM replacement fan clutch is?
              Don
                Don
                Don -
                Paragon has the GM replacement fan clutch for $125.00, less your 10% NCRS discount.
