Greetings -
Has anyone who has straightened Holley carb parts used heat to facilitate the process? Clem, I recall you posting a picture of a fixture you've used to straighten Holley metering blocks.....??
If heating has been successfully used, what temperature?
I'm faced with a 3810 main body whose metering block surfaces are significantly "warped". The throttle plate mounting surface looks pretty flat. The distortion is near the bowl attachment holes. I fear that simply machining those areas to make the surfaces flat would weaken them and make future warping likely....
Bob S.
Bob S.
