1962 passenger door adjustment - NCRS Discussion Boards
  • John F.
    • March 23, 2008
    • 2415
    The bottom rear of the passenger door is out of adjustment. It was pretty much ok before I started jacking and working on brakes,etc. Any easy way to adjust it? John
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11334
    Re: 1962 passenger door adjustment
    John......something was likely loose before you raised it. My guess is the bolts holding the door hinges are loose. With the door open, trying pulling up and pushing down to see if it moves. If it does you should be able to tighten the bolts and get it right. Trial and error......
    If it's the bolts inside the door holding the hinges, you have a little more work to do to get at them.
    Rich
