67 Front Suspension - NCRS Discussion Boards
67 Front Suspension
+ More Options
Posts
  • Dennis L.
    • August 31, 1997
    • 1
    67 Front Suspension
    Should the rear bolts for the lower A's on a 67 have 9/16 nuts with lock washers or a self locking nut?
    Also, should the upper A arm studs have locking nuts or nuts with lock washers?
    My 1966 purchased from the original owner and un-restored used nuts with lock washers in both of these areas. Did anything change in 67?
  • Joseph T.
    • March 1, 1986
    • 169
    Re: 67 Front Suspension
    Dennis,
    Referring to the attached photo, On 1967's the rear nuts (7/8")for the lower A-Arms are locking. The washer is serrated and assembles on the bolt head side with the washer serrations toward the frame.
    The upper A-Arm nuts for 1967's are locking with no washers(11/16"). If you refer to the photo ,you will notice, These nuts will also have a circular indentation on both sides . The plating on both nuts are zinc.
