Plastic Vacuum Valve Brake Booster - NCRS Discussion Boards
  • Erv M.
    • February 21, 2007
    • 445
    I need to know if this is the correct vacuum valve that attaches to the brake booster for a 69. Also It states in the TIMJG that it is painted black; so what paint should I use.
    • 15630
    Re: Plastic Vacuum Valve Brake Booster
    Irv, I don't know why, but I can't click on the image to make it bigger -- so I can't tell if it is the right valve.
    The valve was in place on the booster when it (the booster) was painted -- so the answer is use the same paint that was used on the booster.
    • Erv M.
      • February 21, 2007
      • 445
      Terry,
      I hope this picture will work for you. I see it should be painted gloss black, any recommendations?
      Erv
        • 15630
        For whatever reason this photo worked better. I believe you have one of the styles that will pass judging.
        Here is another.
        • Jeffrey S.
          • May 31, 1988
          • 1898
          Erv:
          As Terry said the paint is the same as the booster but Krylon makes a paint designed for plastic called Fusion. It might adhere better than other types and is available in gloss.
          Jeff
