Knock-off Wheel Replacement - NCRS Discussion Boards
  • Harry L.
    • December 22, 2008
    • 370
    If I am out on the road and have a flat tire, and I take off my knock-off wheel, and when I try to put another tire, it does not fit because of the brake caliber being too close to the side to get a regular tire on, do I have to buy another knock-off wheel assembly or is there some kind of extension I can bolt on my hub so the tire won't rub against the caliber?
  • David D.
    • December 1, 1977
    • 231
    Re: Knock-off Wheel Replacement
    You can purchase another knockoff for $350 and have the proper spare, or purchase a rim that matches the year application of your car to use once you remove the adapter.
    David Dawdy
    • Jerry G.
      • February 1, 1989
      • 228
      Harry: You will need another knock off or just remove the knock off adapter from the hub, then use your regular spare. If you remove the adapter, don't forget the lug nuts for the spare.
