'63 Coupe, wrong bell housing? - NCRS Discussion Boards
  • Scott S.
    • June 22, 2008
    • 9
    Considering a car with an incorrect, 3858403 bell housing. Is this something that could be replaced relatively easily without any worries, thus adding to matching numbers? I've seen a few correct bell housings for sale out there.
    Thanks for the help.
    P.S. - BTW, if anyone has any leads on correct '63 coupes, 300 or 340HP, low mile, no rust car, papers, I'd be interested. Please PM me if so.
  • Wayne M.
    • March 1, 1980
    • 6414
    Re: '63 Coupe, wrong bell housing?
    Originally posted by Scott Smith (49163)
    Considering a car with an incorrect, 3858403 bell housing. Is this something that could be replaced relatively easily without any worries, thus adding to matching numbers? I've seen a few correct bell housings for sale out there....
    Scott -- were not '403' bellhousings correct for latter 1963 production ? Going by Noland's Vol 2 (I don't have the '63-4 TIM&JG's) the changeover from the 3788421 casting was somewhere around VIN 14500.
    I think the earlier BH went with the Borg Warner trannys; not sure if the '403' was strictly a Muncie thing; I'm sure others will report.
    • Tom H.
      • December 1, 1993
      • 3440
      I believe the 403 would be considered correct for a late car. What is the VIN of the car in question ? Scott, if you don't have a 5th edition judging guide, go get one. It is a huge help on 63's. Just when you think you have them figured out, they go late, early... etc.
      Tom Hendricks
      Proud Member NCRS #23758
      NCM Founding Member # 1143
      • Joe R.
        • July 31, 1976
        • 4550
        BW T-10's and the later Muncie both had small aluminum bearing retainers so the 421 bellhousing were used. Never saw a 63 with the later 403's but that don't mean it never happened. If it did the aluminum bearing retainer had to be discarded and replaced with a cast iron. I've seen them (cast iron) with the smaller bolt pattern but never small enough to fit in a 421 bellhousing.
        JR
        • Scott S.
          • June 22, 2008
          • 9
          The car is in the 8700 range. Any chance that the "403" is correct?
          • Harry S.
            • July 31, 2002
            • 5295
            Scott, suggest you look for a 421. Also, do you know if you have the original transmission. It should be a T10 and the VIN sequence number is stamped on it. If you have a later trans, post 63, that probably will not fit the 421.
            • Scott S.
              • June 22, 2008
              • 9
              Will do.....
              • John D.
                • December 1, 1979
                • 5507
                Scott, As mentioned you need a 421. My 63 in the 9900 range has a 421. These are also dated but it's so obscure you can't see it. Don't ask me where the date is as I forget.
                I used to wonder why this part never brought any big bucks until I was told that millions of cars used this bell housing. Readily available at most fleas. Watch for cracks though. JD
                • Michael H.
                  • January 29, 2008
                  • 7477
                  JR
                  I agree with Joe. All 63's with 4-speed used the 63 only 421 housing. Every one.
                  The 403 housing for 64 had a larger opening for the larger transmission front bearing retainer.
                  • Nick M.
                    • September 30, 2005
                    • 143
                    John
                    Happy, Healthy New Year. Hope all is well.
                    63 FI SWC, Top Flight 2006/2008, PV 2007
                    69 Coupe, 427, 400HP w/AC
                    72 LT1 Targa Blue Convertible - Duntov Award
                    07 Z06, Black/Black - Daily Driver
                    • John D.
                      • December 1, 1979
                      • 5507
                      Originally posted by Nick Minoia (44662)
                      John
                      Thanks very much stranger. Take care of the 63. Hope to see you soon. John
