Removing headlight actuators - NCRS Discussion Boards
  • Christopher T.
    • August 27, 2008
    • 15
    I have a '73 with A/C and I need to replace the headlight actuator's. I can't seem to get them out. My question is, does the A/C condenser have to be removed in order to get the actuator's out?
    • 3416
    Re: Removing headlight actuators
    Hi Chris,
    I looked in my 71 Chassis Service Manual and there's no mention of the condenser.
    It only notes to "slide them down", to get them out. Sorry!
    • Christopher T.
      • August 27, 2008
      • 15
      My manual say's the same thing, however the A/C condenser is definately in the way. What I'm calling the A/C condenser is a radiator looking thing that sets in front of the radiator.
      • Jeffrey S.
        • May 31, 1988
        • 1890
        Chris:
        The A/C condensor does not have to come out. If memory serves, I removed mine from my '69 with A/C from the bottom. You will need to turn them every which way to find just the right angle to get them through. I also think I removed the front grills for access.
        Jeff
        • Christopher K.
          • September 10, 2007
          • 311
          Chris,
          I just removed mine, had them replated, and reinstalled them on my '73. I don't have a/c but I wouldn't think it would make a difference. I first raised headlights, removed front grills, took off the four bolts holding the actuators, and was able to remove them through the gap in the open hood. If you have a nice paint job put some tape on your hood first!
          There a good how to with pics on corvette magazine
          Here's the link http://www.corvettemagazine.com/content/view/86/
          Good luck,
          Chris
          Chris
          '72 Lt-1 a/c Pewter Silver coupe Mason Dixon Chapter Top Flight 2016
          '73 L82 4 spd Dark Metallic Blue coupe Chapter Top Flight 2023
          • Harmon C.
            • August 31, 1994
            • 3228
            Through the top as Chris noted is the way I get them out. With a helper you can gain a little room if needed by removing the hood prop bolts.
            Lyle
            • Christopher T.
              • August 27, 2008
              • 15
              Thanks for the help. After thinking about it all last night, I realized, with the hood open the actuator's couldn't raise enough to clear the bracket they bolt into. With the hood down, they're come out of the bracket and slide out the grill opening!! Another mystery solved. Thanks again guy's.
                • 3416
                Hi Chris,
                Now THAT piece of information belongs in the Chassis Sevice Manual.
