63 vin plate - NCRS Discussion Boards
63 vin plate
  • Michael G.
    • November 12, 2008
    • 2157
    63 vin plate
    My April built 63 has a welded vin plate and I have always though that all 63s had this. I'm looking at another very early car whose vin plate is riveted. Anybody know if it was possible for any very early 63's vin plate to be attached with rivets at St Louis?
    Mike
    1965 Black Ext / Silver Int. Coupe, L84 Duntov, French Lick, 2023 - Triple Diamond
    1965 Red Ext / White & Red Int. Conv. - 327/250 AC Regional Top Flight.
  • William C.
    • May 31, 1975
    • 6037
    Re: 63 vin plate
    I once owned S/N 1327, and it was welded. Are the rivets small or large, totally round or serrated? Picture would help.
    Bill Clupper #618
    • Mike M.
      • May 31, 1974
      • 8400
      Re: 63 vin plate
      the early,mid and late 63's i own or have owned all had the vin plate spot welded to the crossbar.mike
      • Tom H.
        • December 1, 1993
        • 3440
        Re: 63 vin plate
        The VIN plate on my Jan built 63 is welded. The only way I've ever seen a 63 plate.
        Tom Hendricks
        Proud Member NCRS #23758
        NCM Founding Member # 1143
        • Philip C.
          • December 1, 1984
          • 1117
          Re: 63 vin plate
          Hi Mike sometimes you will find them riveted because the plates have falling off,(quick fix to pot rivet) the welds didnt hold very well on some of them, thats why you sometimes see them spot welded two or three times on each side. esp if the dealer stamped date of delivery on the plate, it could loosen it up. Phil 8063
          • Mike L.
            • January 1, 1986
            • 312
            Re: 63 vin plate
            I once owned 1963 Corvette #300, black coupe, the vin. plate was welded.
            • Tom H.
              • December 1, 1993
              • 3440
              Re: 63 vin plate
              Any evidence of a prior weld and then a rivet ? You can usually tell where the welds were on the "z" bar and the vin tag, itself.
              Tom Hendricks
              • Michael G.
                • November 12, 2008
                • 2157
                Re: 63 vin plate
                Here's a poor photo of the rivet. It doesn't look like a scaloped rivet, but, I'll haveto get a better look. I'll also check for failed welding attempts, etc. The vin tag also seems to be closer to the trim tag than I've seen.
                Thanks, Mike
                Mike
                • Chuck G.
                  • May 31, 1982
                  • 2036
                  Re: 63 vin plate
                  All the 63 VIN tags I've seen have been spot welded, once, sometimes twice on each end.
                  I've never seen a 63 that had the VIN tag RIVETED on ORIGINALLY.
                  Now, if it fell off......a previous owner could have pop riveted it back on, or...............could be something else, like a changed VIN plate.
                  Chuck
                  • Tom H.
                    • December 1, 1993
                    • 3440
                    Re: 63 vin plate
                    I've never seen a 63 that had the VIN tag welded on ORIGINALLY.
                    Chuck
                    Chuck:
                    I think you meant you've never seen one "riveted" ORIGINALLY
                    Tom Hendricks
                    • Joe R.
                      • July 31, 1976
                      • 4551
                      Re: 63 vin plate
                      Chuck
                      Chuck,
                      Better read those messages before clicking that send button. Er, could it be part-timers?
                      JR
                      • Chuck G.
                        • May 31, 1982
                        • 2036
                        Re: 63 vin plate
                        Originally posted by Tom Hendricks (23758)
                        Chuck:
                        Yep, brain cramp. Went back and edited the post.
                        It's tough getting old. Be kind to your elders.
                        Chuck
                        • Tom H.
                          • December 1, 1993
                          • 3440
                          Re: 63 vin plate
                          Chuck
                          Oh, I was kind and always respect your posts, Chuck. Just wanted to make sure your post was clear for the OP !!! I'll be old sometime too !!
                          Tom Hendricks
                          • James G.
                            • May 31, 1976
                            • 1556
                            Re: 63 vin plate
                            Chuck
                            I hate for you to go here, but if the car is one you want to buy, you might check the vin number on the frame to make sure they are the same.
                            • Michael G.
                              • November 12, 2008
                              • 2157
                              Re: 63 vin plate
                              I think you're right, Jim....that could be an issue
                              This car is probably worth a little research, but, I don't want to get involved in anything with a questionable vin. I had intended to restore it, so if its a real car, not a vin switch, what affect would somethig like a vin attachment issue have on the car in judging?
                              Mike
