63 Upper Steering Wheel Bearing Confusion - NCRS Discussion Boards
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11324
    Re: 63 Upper Steering Wheel Bearing Confusion
    Ok...... the hole in photo 1 below?
    But what about that connector I have with the little round clip that was fitted over the air vent cable(photo 2 in my prior post). What's that all about?
    Rich
    • Paul Y.
      • September 30, 1982
      • 570
      Robert, The one I installed back in the early 80's was green also but I will look for the one that came out of the car because it could very well have been black. I guess that I thought that it matched the color of the ones that attached to the horns. Rich, my connector has that clip also and I will see if I can get a picture. My 63 is later though at about June 7 so my info might be different as you well know.
      It's a good life!
      • Paul Y.
        • 570
        #18
        Rick, Ok, I'm wrong or confused or both. I checked on mine which was replaced in the early 80's and it has the female recepticle on the bearing side. I have enclosed a photo of it w/out the plastic connector.
        It's a good life!
        • Richard M.
          Super Moderator
          • August 31, 1988
          • 11324
          #19
          Thanks for checking Paul......
          Ok, now it's making sense. Maybe the service replacements had a note in the parts book to change the male terminal on the bearing wire on certain cars.
          So you have the special clip connector too. I wonder what the part# was. The AIM date for the change to using electrical tape was January.
          Rich
          • Harry S.
            • July 31, 2002
            • 5309
            #20
            Rich, I see you live in Florida. There are usually piles of wire and plugs at the Kissimmee Regional. That plug is not an odd size as I recall. Take a ride over to the meet.
            • Richard M.
              Super Moderator
              • August 31, 1988
              • 11324
              #21
              I'll be there for sure. Wouldn't miss it.
