Need help identifying 1969 Ignition shielding brackets. - NCRS Discussion Boards
  • John M.
    • November 10, 2008
    • 364
    These look close, but are identified as 1970-1978.
    I notice subtle differences on these brackets through the years, so may need a little help identifying the correct brackets.
    Thanks much.
    A confusing variety:
    • 15606
    Re: Need help identifying 1969 Ignition shielding brackets.
    Those are small block brackets, and since they have a single weld nut they are for the later 1970 and up single-piece ignition shielding. They will not work for any properly equipped 1969.
    • John M.
      • November 10, 2008
      • 364
      These are correct then not having the welded nuts?
      http://cgi.ebay.com/ebaymotors/ws/eB...64166&viewitem=
        • 15606
        No John,
        For the 1969 box-type distributor shielding the supports should each have two weld nuts on them. There is a good drawing that shows that in the TIM&JG. The box type shielding (two piece style for 1969) uses a total of four wing bolts to attach it to the supports -- thus the total of four weld nuts.
        BB supports will also have a stud welded to the inside (same side as the weld nuts) to attach the wire shielding to ground.
        SB, of course, don't have that stud. There are also shape differences between the BB and SB supports, but I don't have the words to describe them. Even my Irish heritage doesn't work for that, even earlier in the day.
        • John M.
          • November 10, 2008
          • 364
          Boy that makes it tough. I didn't see any pictures in the 68-69 TIM & JG, but they do referance the (2) weld nuts.
          I imagine these are tough to find as they're not reproduced.
          Even harder to find when your not positive what your looking for.
            • 15606
            Sorry John. They took the ignition shielding drawing out of the last 1968-69 TIM&JG revision. It is still in the 1970-72 TIM&JG. My mistake. I kind of liked that drawing, but I wasn't aware they took it out of the new edition.
            • John M.
              • November 10, 2008
              • 364
              It looks like Doc Rebuild carries GM Factory replacement brackets.
              Thats an option.
              • Jeffrey S.
                • May 31, 1988
                • 1890
                John:
                Attached is the AIM page for this support. A picture is worth a thousand words.
                Jeff
                • John M.
                  • November 10, 2008
                  • 364
                  Thank You Sir, I appreciate it.
