Question for Bowtie 1960 - NCRS Discussion Boards
+ More Options
Posts
  • Mark P.
    • May 13, 2008
    • 951
    If you have a Bowtie 1960 can you tell me what numbers you see on the weight for the heat riser valve below the right hand manifold.
    Does it look this ?
  • Gary C.
    Administrator
    • October 1, 1982
    • 17940
    Re: Question for Bowtie 1960
    Mark, Dave Smith took these photos of his '57 Bowtie heat riser valve. '57's have TOP cast into the top of the flange whereas '58's have an UP. Gary....
    NCRS Texas Chapter
    https://www.ncrstexas.org/
    • David S.
      • December 1, 1982
      • 310
      Hi Mark,
      Gary Chesnut suggested that I post a few pictures of a NOS valve Assy. that I have had in my possession for a number of years.
      I see a little difference in the location of the #s on the weight.
      Dave
      • Gary C.
        Administrator
        • October 1, 1982
        • 17940
        Mark, my Chevy friend tells that all the exhaust heat riser valves that have "UP" cast on them were used from mid-to-late 58 through 62. 57 to mid-to-late 58 has "TOP" cast. Dave Smith's photos in this post shows the correct heat riser valve for your application. Gary....
        NCRS Texas Chapter
