1962 Engine compartment straps - NCRS Discussion Boards
  • John F.
    • March 23, 2008
    • 2415
    I have a new set of the aluminum starps that hold wire/hoses. Can anyone with a 62 point me in the right direction of wher in the engine compartment they go?
  • Terry R.
    • March 1, 2005
    • 359
    Re: 1962 Engine compartment straps
    Hi John The assembly manual has some really good detail on location. I don't have a copy with me but it's there.
    • John F.
      • March 23, 2008
      • 2415
      Terry, the only two I can see in the AIM are on the hoses near the generator and one somewhere near the w/w hoses. The manual is not that clear to me. John
      • Terry R.
        • March 1, 2005
        • 359
        Hi John Section B Sheet 11 shows 5 of them on WW hoses key 5. Then on Section B Sheet 15 it shows one on heater hoses 5.50 in. from the angled nipple on pump. Sounds a little critical but if you put it like it shows you don't have to worry about the hoses getting into the belt. Good Luck
