c-1 3.70 ring pinion availabilty - NCRS Discussion Boards
  • Louie C.
    • March 1, 1980
    • 43
    Does anyone know of a reliable brand, or used 3.70 ring and pinion for my '60. Also, where do you get replacement clutch packs for the posi?
    Lou
  • Pierre J.
    • July 31, 2000
    • 193
    Re: c-1 3.70 ring pinion availabilty
    Bought a 3.7 Richmond gear last year. You can get them at:
    http://www.jegs.com/i/Richmond+Gear/...099-1/10002/-1
    Pierre
    • Louie C.
      • March 1, 1980
      • 43
      Really looking for a 10 and 37 count like original
      • John N.
        • February 1, 1975
        • 451
        I believe the Richmond is a 3.73. U.S. Gear has a 3.70. Do not know what the tooth count.
        Regards
          • 43211
          Lou
          Lou-----
          You should be able to obtain what you need from Tom's Differentials (www.tomsdifferentials.com) or Randy's Ring and Pinion (www.ringpinion.com). If neither one of these sources can help you, then I'd say you're out-of-luck. However, I feel very confident that they'll have what you need.
          I recommend ring and pinion gear sets manufactured by U.S. Gear of Chicago, IL. Their product is most similar to the original GM product. These are often much harder to find than Richmond Gear gear-sets. However, I think that Tom's Differentials, if not Randy's, will have them. U.S. Gear DOES NOT SELL DIRECT.
