63' Z06 brake shoes - NCRS Discussion Boards
63' Z06 brake shoes
  • John A.
    • February 1, 1982
    • 48
    63' Z06 brake shoes
    Can anyone tell me what the "right" numbers are, for the front/rear brake shoes on a Z06? I have a set numbered 5464662(f), and 5464663 (r). Are these correct?
    Thanks, John
    • 43219
    Re: 63' Z06 brake shoes
    Thanks, John
    John-----
    The only part numbers ever available from GM for 63-64 with J-56 brakes was GM #3846286, front, and GM #3846287, rear. These were Chevrolet part numbers. It's possible that the numbers you mentioned were a Delco part number for the same shoes, but I have no information to indicate that. I can't find any record of those numbers, either. Where are you finding these numbers? On a BOX that the brake shoes are supplied in or somewhere on the shoes themselves?
    • John A.
      • February 1, 1982
      • 48
      These #s appear to be ink stamped on the center rib of the shoe.
      • Bob J.
        • December 1, 1977
        • 714
        John-----
        Joe, you'll need to check an earlier P&A than 8-63.
        The shoe part numbers you listed are actually 64 J56 shoes which have different size segments than the 63 Z06 shoes. Bob
          • 43219
          Bob-----
          Yes, the numbers I posted were for a 1964 with J-56 and were SERVICE for 1963 with J-56. For some reason, I had 64 on my mind even though the original post clearly stated 1963 and Z-06. The 1963 part numbers were GM #3794196, front, and 3794201, rear.
          • Stuart F.
            • August 31, 1996
            • 4676
            Joe;
            I had "Carolina" on my mind (Neil Diamond, Rolling Stones or Melanie - take your pick).
            Stu Fox
            • John A.
              • February 1, 1982
              • 48
              How many segments should the front and rear shoes have?
              John
