Battert Tender/Butler - NCRS Discussion Boards
  • Jack C.
    • September 30, 1992
    • 1090
    I just purchased the battery Butler from Lectric Unlimited. Other than following the simple instructions, any thoughts? My repro R89 is still in the car with the diconnect knob disengaged, do I need to take both cables off the battery or just hook up the Butler? Happy New Year
    Jack Corso
    1972 Elkhart Green LT-1 Coupe 43,200 miles
    Top Flight 1994, 2018 & 2021
  • Donald O.
    • May 31, 1990
    • 1593
    Re: Battert Tender/Butler
    Just connect it to the battery and plug it in for the winter.
    • Anthony S.
      • April 3, 2008
      • 183
      Jack,
      You have to connect the negative clamp on the post of the battery when using the disconnect. If you clamp onto the other side of the disconnect, it will not charge. You will be able to tell by watching the LED's.
      Other than that, set it & forget it.
      Anthony
      • Fenwick B.
        • January 1, 2005
        • 115
        I have 3 of them, and they work great. If your battery is in good condition, and there is not too much drain on the system, the light should blink every few seconds. I have one that won't blink though. Fenwick
        • Michael L.
          • December 1, 1998
          • 97
          Re: Battery Tender/Butler
          Hi all
          Like said they work well
          Michael E Leeds
          Charter Member
          Past Chairman Louisiana Chapter
          Past Vice Chairman Louisiana Chapter
          Past Show Chairman
          31462-La-46
          River Ridge LA
          www.ncrs-louisiana.com
          • Jack C.
            • 1090
            Thanks guys.
            Jack Corso
            • Kurt B.
              • July 31, 1996
              • 971
              I have them on all my vehicles and some sit for months and when I hit the key it is as though the battery was jsut installed.
              I love them and recommend them
              Kurt 26406
              • Gerald C.
                • June 30, 1987
                • 1311
                I have a 2003 C5 and when I put this charger on, the "Trouble" light comes on. It's a new battery. Instead of using the clamps on the charger to the side posts, should I hook up the permanent attachment and use the plug in instead of the clamps?
                  Gerald -
                  Don't know what brand you have (the "Battery Tender" doesn't have that light), but are you sure you have it connected correctly?
                  • Gerald C.
                    • June 30, 1987
                    • 1311
                    It is called a Battery Companion. It's set to 12 volts and I hooked up red/red and blk/blk. I also tried it on another battery and receive no red trouble light.
                      • 15635
                      Test the battery -- maybe it is dead. These battery maintainers will not charge a dead battery.
                      • Stuart F.
                        • August 31, 1996
                        • 4676
                        If you have a wet battery like mine, you want to check your levels in the cells every so often. During the hot summer months (not your problem, right?), I've had mine go dry (low) in a few cells. Not sure if it was boiled out or evaporated, so I check it as part of my start up procedure - that and my brake fluid.
                        Stu Fox
                        • Mark R.
                          • September 30, 1990
                          • 127
                          Hi Jack:
                          Sure hope your outstanding 1968 Le Mans Blue beauty is comfortably sheltered from the New Jersey winter. Spring cannot come soon enough for this Jersey Corvette guy.
                          I've been using the Battery Tender Plus on my 1970 and 2003 Z06 for years, with excllent results. On my 1970, I have a battery cut off and hook the Battery Tender Plus clips to the posts. Both cars see minimal activity; so,right after the occassional drive, the Battery Tender Plus is re-installed. When I decide to go for a ride, the ignition key is installed and the car starts right up. Why argue with success ?
                          Mark
                          • Phil D.
                            • January 17, 2008
                            • 206
                            I caution anyone considering one of these to avoid the new Sears Diehard battery maintainers. I had one Sears Diehard battery maintainer that was several years old and worked great. Its about the size of a brick and weighs as much as a brick. I liked it so I bought another one. The new ones from Sears look just like the old one, but are light as a feather. That new one seemed to work fine too. A year went by and I got a couple more cars so I bought two more Sears units. One failed after a couple of days and would not shut off, constantly charging the battery. I caught it before any real damage was done. I thought it was just a fluke and so I exchanged it. The exchange was "dead on arrival." Meanwhile, the other brand new Sears unit developed a loud hum and I was afraid to leave a car plugged into it. So I took them back and got a refund and went and bought the more expensive Battery Tender brand to replace them. A few days later, the year-old Sears unit started making unusual "noises" and so I unplugged it. The old "brick" Diehard is still trucking, but three new style Diehards in a row, died hard. Just thought I'd post so nobody else would make the same mistake I did.
