Re: easy one: flash chrome..what processes from triple plating do you bypass?
I was always under the impression chrome is basically clear, it was plated over nickel and that the term triple chrome plating only referred to one additional plating- copper. The copper was used to fill any slight flaws/pitting in the bare steel since it is very soft and easy to buff smooth. I deal with a first/second tier OEM plater who doesn't ever use copper on the new parts but nickel then chrome. He has polished some parts for me and then nickel/chromes them and they look great. It would seem to me that putting chrome directly on steel, you would have to polish the substrate to a brilliant shine to get a good result and on production work that would be impossible. Someone please set me straight. Removing the old chrome is very easy if you have a good source of DC current. The part gets put into a sufuric acid bath and the positive is put on the part and the negative is put on some steel. The chrome and nickel (and copper) come off the part and plate the steel. I do this quite often and it leaves a perfectly clean unmarked part.
Jeff
Jeff
