Brake Bleeders - NCRS Discussion Boards
Brake Bleeders
  • Justin B.
    • March 1, 1996
    • 478
    Brake Bleeders
    Can anyone make a good recommendation of where I can buy a good quality, simple to use, one man brake bleeder system for when I'm ready to bleed the brakes on the freshly restored 58' ? I know how to do it the old fashioned way but I would like to find an easier, cleaner way of doing this. Thanks
  • Ken B.
    • May 31, 2006
    • 233
    Re: Brake Bleeders
    I have used solo bleeders from Earls and have very much luck with them.Summit racing has them not sure it they are available anywhere else.Make bleeding a snap.
    • Gary C.
      Administrator
      • October 1, 1982
      • 17942
      Re: Brake Bleeders
      Justin, have the MityVac 6835 and it works great. Gary....
      http://www.devildogtools.com/mi68vabrblki.html
      NCRS Texas Chapter
      https://www.ncrstexas.org/
        • 43285
        Re: Brake Bleeders
        Justin-----
        Keep Your Fluids at Peak Performance. Get professional results with the our one-man bleeder and fillers.
        • John F.
          • March 23, 2008
          • 2423
          Re: Brake Bleeders
          I say it's best to share the experience with another corvette guy or loved family member. I just did it by myself since my wife is disabled, but she really enjoys the rides with her hair blowing in the wind, like when we were dating in college and sold our last 62 for $2500 before we got married. Close all the bleed valves and keep filling the reservoir with fresh fluid while having a friend/spouse pump the brakes starting with the rear cylinders.I used DOT-5 and worked my way all around the car. Then while still on jack stands look for leaks. Use a clear hose into a milk jug. Do not pump the brakes with the drums off for various reasons. I then took all four drums off one-by-one and kept tightening up the star-wheel until you get some good drag then back off seven clicks. It's much easier with the drums off. Keep filling up and pumping, you should get good pedal pretty quick. Take it for a test drive in a safe manor, then tweak it if necessary. Worked for me! Have a wonderful New Year and enjoy that car. I plan to. God Bless all the coalition troops and let them return home safely. Why not tak a "vet" for a spin if you know one and tell them thank you! John
          • Joe R.
            • July 31, 1994
            • 287
            Re: Brake Bleeders
            I'm with Joe Lucia on the Motiv Products power bleeder. Works flawlessly on my 54 and the rest of the stable aS well.
            • Justin B.
              • March 1, 1996
              • 478
              Re: Brake Bleeders
              Checked out their website....which pump should I buy and should I get one of their adaptors or any other parts?
              • Brian M.
                • February 1, 1997
                • 1842
                Re: Brake Bleeders
                I still prefer the suction method of the Vacula system. Vacual.com
                  • 43285
                  Re: Brake Bleeders
                  Justin-----
                  #0105 includes the pressure bleeder and the master cylinder adapter for 1967-82 Corvettes. For your 58, I'm not sure which adapter is required. You'd need to call them unless someone here knows.
                  • Bill M.
                    • April 1, 1977
                    • 1386
                    Re: Brake Bleeders
                    Justin:
                    Before you use a pressure bleeder on a C1, look in the archives for a thread on the plug getting blown out of the master cylinder.
                    Bill
                    • Kenneth S.
                      • July 31, 1981
                      • 302
                      Re: Brake Bleeders
                      I put Speedbleeders on my '63 and they are great. Working alone, I change out the brake fluid every few years and the whole process takes less than 30-minutes.
                      • Harry S.
                        • July 31, 2002
                        • 5345
                        Re: Brake Bleeders
                        Kenneth, do you have a link to the product or a picture?
                        • Kenneth S.
                          • July 31, 1981
                          • 302
                          Re: Brake Bleeders
                          http://www.speedbleeder.com/ I also ordered their bag and hose and it makes the job, what used to always end up being a mess, clean and neat.
                            • 3420
                            Re: Brake Bleeders
                            A basic dummy question please.
                            On stock bleeders, when they're loosened, why does the fluid come through the valve rather than around the bleeder threads?
                            Happy New Year!
                            • Michael G.
                              • March 2, 2008
                              • 487
                              Re: Brake Bleeders
                              It's the path of least resistance Alan. The bleeder valve is plugged when seated and provides a good path through the bleeder when loosened. If the bleeder valve had an obstruction (dirt) in the opening, then the threads would actually bleed the fluid. Happy New Year, Mike
