9 leaf, spring question - NCRS Discussion Boards
  • Michael H.
    Infrequent User
    • March 1, 1990
    • 26
    I just changed over from a 7 leaf with a spacer plate to the correct 9 leaf spring on my 1966 big block. Can anyone tell me the correct length of the 4 bolts mounting the springs to the carrier cover? The length used to mount the 7 leaf were hardware store bolts 3 1/2". When I reused the bolts, the two bolts in the rear of the cover seem to hit bottom. Like they were to long.
  • Stephen L.
    • May 31, 1984
    • 3162
    Re: 9 leaf, spring question
    The correct bolts are 9/16 - 12 - 3-1/4, black finish.
    • Gary B.
      • February 1, 1997
      • 7066
      Spring attachment bolts too long
      Michael,
      I hope you didn't try and fully tighten those hardware store bolts that were too long. It's possible to punch thru the case using bolts that are too long and doing that will definitely ruin your day.
      Gary
      • Michael H.
        Infrequent User
        • March 1, 1990
        • 26
        Thanks for the reply Gary. I stop as soon as the bolts hit bottom.
        • Curt C.
          • May 31, 2000
          • 49
          Michael, I know Gary's point first hand. He was right, it did ruin my day and get rear end lubricant all over my garage floor!
          • Wayne M.
            • March 1, 1980
            • 6414
            But most importantly, the threaded portion is only 1.0" (ie 12 threads) long. Also, those split lock washers are 0.175" thick.
            • R N.
              • May 31, 2002
              • 640
              Hello All,
              Reading this with interest and that generated a question - Is there a difference between these bolts for standard 9-leaf spring and that of the 7-leaf F-41 spring?
                • 43273
                Originally posted by R. Kurt Neiman (38038)
                Hello All,
                Kurt-----
                The bolts were the same regardless of installed spring.
                  • 43273
                  Michael-----
                  These bolts have an "official" length of 3-1/8", although in actuality I think they're a little bit longer. However, they are special bolts inasmuch as they have a long, unthreaded shank and relatively short thread length. Paragon makes an excellent reproduction of these bolts.
