Sill plate scratch repair - NCRS Discussion Boards
  • Randy R.
    • March 1, 1983
    • 477
    The sill plates on my 67 have some minor scratches. I can feel them with a finger nail. I found a company that will anodize them but they do not strip the existing anidizing or remove the scratches. Does anyone have any tips for doing this?
    Thank you,
    Randy
  • Steven B.
    • June 30, 1982
    • 3997
    Re: Sill plate scratch repair
    Randy, I have not removed anodized but I believe Paul's Chrome Plating will do it all.
    Steve
    • Mike G.
      • January 1, 1991
      • 418
      Anodize removal
      I recall that Caswell's plating supplies now offers a chemical stripper for anodize. Some sort of caustic solution. Also, I've read that heavy-duty oven cleaner (also lye based) works as well.
      Of course, I learned all this after hand sanding my sidepipe covers so I could polish the ribs! That anodize is some HARD stuff...
      If you go with Caswell's liquid, suggest getting a plastic tray used for wallpaper wetting -- long and skinny.
      • Stephen L.
        • May 31, 1984
        • 3159
        EASY-OFF oven cleaner will remove anodizing. Spray it on..... wait for about 20 minutes and use steel wool to remove. You'll probably need to repeat procedure a few times.
        I tried the expensive stuff from Eastwood with no better success.... maybe a little worse.......
        Who does the anodizing??? I have a few pieces that I'd like to get done.
        • Randy R.
          • March 1, 1983
          • 477
          Thank you for the tips. I dig out the name of the company.
          Randy
