1956 Carter Carb Tag Decode - NCRS Discussion Boards
  • Charlie P.
    • July 31, 2003
    • 260
    I hope I can sneak in one question here that actually pertains to a '56 Cadillac Carter carb (once I get to work on my 7,300 mile '81, I'll have real Corvette questions).
    Assuming the system is the same regardless of the GM make the carb is on, how do you decode the brass tag? Is there a date embedded in it? The top area of this tag shows 2334S, one "box" in the lower area has L5, with a 4 under it.
    Thanks much.
  • Gary C.
    Administrator
    • October 1, 1982
    • 17697
    Re: 1956 Carter Carb Tag Decode
    Charles, 56-7 Corvette carb ID Tags stampings. Gary....
    - Manufacturing Date Code = A for Jan, B for Feb, etc.... followed by the year 6 for 1956, 7 for 1957
    - Carb model no. is stamped
    original tag photo attached - photo courtesy Bernie Myers
    NCRS Texas Chapter
    https://www.ncrstexas.org/
    • Steven B.
      • June 30, 1982
      • 3990
      Gary, in the lower left corner, before the date section, what is the "cutout"? Are there different symbols for different WCFB's?
      Thanks!
      Steve
      • Roy B.
        • February 1, 1975
        • 7044
        Thanks!
        Steve
        Those are inspection and may vary in design or amount , repro's don't have them.
        • Steven B.
          • June 30, 1982
          • 3990
          Thanks Roy, because that one does not look like either of mine and i was wondering!
          Steve
          • Charlie P.
            • July 31, 2003
            • 260
            Thanks Gary, makes sense. This car was built Dec. 14, 1955, and the carb tag date is L5 (with a 4 underneath), for December '55. I suppose the 4 could mean the 4th of the month?
            The tag also has an inspection punch.
            Thanks again.
            • Chuck G.
              • May 31, 1982
              • 2034
              Thanks again.
              I "think" that the 4 indicates the assembly line or work station at which the carb was built, line 1, 2, 3, 4, etc.
              Chuck
              • Jimmy B.
                • July 31, 1980
                • 584
                Here's an early 57 dual quad tag for you to look at. Note the "4" same as yours.
                Jim Blakely
                • Jimmy B.
                  • July 31, 1980
                  • 584
                  Charles,
                  See if this is any clearer for you.
                  Jim
                  • Charlie P.
                    • July 31, 2003
                    • 260
                    Jimmy- I see the "4" on yours. I see that Gary's shows an "8". Thanks for the pic.
                    • Bernard M.
                      • August 31, 1994
                      • 341
                      Bob Kuntz informed me that the small digit was the assembly line number and is almost always a 4 or an 8. Another feature that distinguishes originals from MOST reproductions is that originals had a turned under edge to help prevent tearing of the light metal. MOST reproductions are die cut with a corresponding clean cut edge.
