My son and I switched cars today on a short cruise, and my clutch pedal didn't like his foot and the rubber pad came off. Now this is the original pad and I have never had any sign of any problem or loosening of it in 45 years. It seems to be cracked in both lower corners. I tried to slip it back on, but it would not go easy w/o a tool. Even then, I suspect I will have to warm it in the Florida sun tommorrow if I try again, and use a pry tool.
Anyone have any advice or suggestions from your experience?
Should I just replace it? or, can/should I use some adhesive on it?
I've never had to replace a pad in my 69 years of protected life, and this one still looks plenty good w/o wear to speak of.
Stu Fox
Stu Fox
bucks - to make sure they last as long as possible I bought black infant socks with the elastic tops and slip them on & off when I get to shows. Works well.
