New 67-68 Standard Strg Column Papers - NCRS Discussion Boards
  • Jim S.
    • August 31, 2001
    • 730
    I have just posted two new steering column papers. They cover the 1967 (late) and 1968 standard (non-adjustable) steering columns.
    This first paper discusses removing and replacing the turn signal switch and upper column bearing.
    This second paper discusses dropping the steering column, replacing the lower column bearing, and checking the steering shaft length.
    I have also posted both of them in pdf format. You will need to go to www.jimshea.corvettefaq.com
    click on Jim Shea's Steering Papers
    click on Corvette Steering Papers
    scroll down to the 67-68 Standard Steering Column section
    download Disassembly & Repair Papers #1 and #2.
    I would be very interested in any comments, suggestions, corrections, etc.
    Now I will have some time to look at the telescoping columns.
    Jim
  • Stephen L.
    • May 31, 1984
    • 3159
    Re: New 67-68 Standard Strg Column Papers
    www.corvettefaq.com site will not open.....
    • Brian M.
      • February 1, 1997
      • 1840
      Is there a know change over ser. # for an early and late 67?
      • Jim S.
        • August 31, 2001
        • 730
        I changed the websight address to www.jimshea.corvettefaq.com
        It seems to work.
        I do not have a cutoff date. For some reason I can find the Chevelle and Corvair campaign information on the NHTSA websight. They give the vehicle identification number break points. But I cannot find the campaign info for Corvette or any other 1967 GM vehicles using the NHTSA search engine.
        Jim
        • Stephen L.
          • May 31, 1984
          • 3159
          Great papers!!!!! Could have used the info a few yrs ago when I "stumbled" thru a rebuild.....
